[lammps-users] converting from pdb to lammps data file
Dear Axel and Lammps-users,
I followed the discussion on the following thread in order to generate a coordinate date file for Lammps. This is my first experience at using a pdb file for MD data-input. As pointed out, I was able to generate the lammps data file without any of the bond angles and dihedrals. Also, values for xlo xhi etc. came 0.0, possibly because further details were not given in the VMD console interface.
I am in the process of setting up an equilibrium MD simulation for CaCl2.6H20 and the pdb file obtained from the net is attached. I was trying to look in the VMD manuals for discussion on topotools so that a complete lammps data file could be generated, but it seems that VMD beta manual is not published, and the older versions lack this feature. Any description or directions on how to build the complete lammps data from a pdb using vmd would be very useful.
Also, this pdb file seems to be missing the hydrogen atoms present in the salt hydrate. Is this normal, and if yes then how should the H atoms be included in data file ?
Thank you.
Ganesh
— On Fri, 19/6/09, Axel Kohlmeyer [email protected] wrote:
> From: Axel Kohlmeyer [email protected]
> Subject: Re: [lammps-users] help regarding converting from pdb to lammps data file
> To: “vishnu gopalakrishnan” <[email protected]…24…>
> Cc: [email protected]
> Date: Friday, 19 June, 2009, 6:46 PM
> On Fri, 2009-06-19 at 16:30 +0530, vishnu gopalakrishnan wrote:
> dear vishnu,
> > dear lammps users,
> > suppose the bonds in pdb is defined as below
> > CONECT 37 34 38 39 56
> > how do we convert this to the lammps data file format???
> you have to be a bit more specific about what is in the .pdb
> file. how many atom types do you have in there? .pdb only has
> the names field.
> technically a conversion is possible using the latest VMD beta version.
> you would type (on the VMD console window):
> mol new filebonds 1
> package require topotools
> topo writelammpsdata
> and e-voila. but this way you would not have angle,
> dihedral definitions etc.
> cheers,
> axel.
> > thanking you
> > vishnu
> > Crystal Reports - New Free Runtime and 30 Day Trial
> > Check out the new simplified licensing option that enables unlimited
> > royalty-free distribution of the report engine for externally facing
> > server and web deployment.
> > http://p.sf.net/sfu/businessobjects
> > _______________________________________________ lammps-users mailing list [email protected] https://lists.sourceforge.net/lists/listinfo/lammps-users
> Axel Kohlmeyer [email protected] http://www.cmm.upenn.edu
> Center for Molecular Modeling – University of Pennsylvania
> Department of Chemistry, 231 S.34th Street, Philadelphia, PA 19104-6323
> tel: 1-215-898-1582, fax: 1-215-573-6233, office-tel: 1-215-898-5425
> If you make something idiot-proof, the universe creates a better idiot.
> [email protected]
cacl2.pdb (813 Bytes)
dear ganesh,
your .pdb file is complete nonsense. it has multiple O atoms at
the exact same location. also CaCl2 is an ionic compound with
no bonds in the sense like they are used by classical potentials.
you would be much better off using the lattice command to set up
the system (after looking up the appropriate space group).
what kind of potential type and parameter set were you planning
to use?
as far a topotools is concerned two remarks:
- topotools is a plugin and thus documented through the VMD plugins
online documentation, which is not (yet) part of the VMD user's guide.
- topotools can only use information that was given to VMD. your .pdb
  file had no information about the simulation cell, so topotools cannot
  know it.
as for the missing hydrogens. if the .pdb file was generated based
on x-ray crystal structure data, then it is normal that there are no
hydrogens. you'll have to find other ways to generate them. search the
literature! i am certain, you are not the first person wanting to
simulate this compound.
cheers,
