Dear Lammps Users,
I want to model body rounded/polyhedron particles (nano cubes) submerged in an lj particle fluid. Kind of like in this paper, but with body particles.
My plan was to have two atom types, one for my cubes (type 1) and one for my lj particles (type 2).
I assume, that it only makes sense to have one atom style (in this case body) so my lj particles also have to be body style particles. Is this correct?
I have one nano cube as a model in a data file which I read and then replicate (this works fine).
The question now is, how do I model the lj particles. I wanted to use the create_atoms command but I have some questions.
Is the create_atom command the way to go, or would it be better do define all the lj particles in the data file?
As a test I used the command like this to create one extra nano cube,
atom_style body rounded/polyhedron 1 10
read_data data.cubes
create_atoms 1 random 1 847857 NULL
But it does not seem to create the nano cube or at least the image suggests that (attached).
If I then use
fix 1 all nve/body
the following error occurs:
Reading data file …
orthogonal box = (-20.000000 -20.000000 -20.000000) to (20.000000 20.000000 20.000000)
1 by 2 by 2 MPI processor grid
reading atoms …
1 atoms
1 bodies
read_data CPU = 0.001 seconds
Created 1 atoms
create_atoms CPU = 0.000 seconds
ERROR on proc 3: Fix nve/body requires bodies (src/BODY/fix_nve_body.cpp:44)
Is the created atom not a body particle? What have I created?
Konstantin
Ps.: I use the lammps-stable from the 29th of October 2020
Input file:
units nano
newton on
create_atoms 1 random 1 48134 NULL
velocity all create 300 156164 dist gaussian mom yes rot yes
variable steps equal 1
comm_modify vel yes
neighbor 0.5 bin
timestep 0.0005
#fix 1 all nve/body
dump image all image 100 image.*.png type type &
zoom 1.0 body type 1 1
thermo_style custom step
thermo 100
run ${steps}
Data file:
#LAMMPS data file for polygons: cubes, moment of inertia I = m edge^2/ 6
1 atoms
1 bodies
1 atom types
-20 20 xlo xhi
-20 20 ylo yhi
-20 20 zlo zhi
Atoms
1 1 1 5.401 0 0 0
#2 2 1 1 0 0 12
Bodies
1 3 79
8 12 6
90 90 90 0 0 0
3 3 3
3 -3 3
-3 -3 3
-3 3 3
3 3 -3
3 -3 -3
-3 -3 -3
-3 3 -3
0 1
1 2
2 3
3 0
4 5
5 6
6 7
7 4
0 4
1 5
2 6
3 7
0 1 2 3
4 5 6 7
0 1 5 4
1 2 6 5
2 3 7 6
3 0 4 7
4.0
