Hi LAMMPS users,
I was using DPD method to simulate a rod-coil copolymer system. The
simulation crashed at timestep 7150 and lammps gave me the following
error message:
ERROR on proc 1: Bond atoms 37802 37803 missing on proc 1 at step 7150
ERROR on proc 2: Angle atoms 37803 37804 37805 missing on proc 2 at step 7150
I have set
communicate single cutoff 10.0 vel yes
The cutoff for communication between different processor is 10, which
I think is big enough. I am a little surprised by this error message,
so I would like to find the distance between atoms 37802 37803, so I
set the sytem to run 7000 steps first, then continuing running another
1000 steps, where I would output the configuration at each step by the
following script:
run 6000 (note: I have run 1000 step for nve before this nvt run)
undump 1
dump 1 all atom 1 debug.nvt.T${tt}.lammpstrj
run 1000
write_restart restart.after.*
I expected the simulation would stop at the timestep 7150. However,
the simulation didn't crash. I don't understand why this happens. The
thermo outputs from two runs are as following:
1. make a long run, crashed at 7150,
Step Temp Press PotEng E_bond E_angle E_vdwl TotEng Dt
6400 1.0967603 21.107456 3.3154345 0.70708241
0.45831164 2.1500404 4.9605358 0.01
6500 1.1251306 21.345061 3.3126857 0.68989945
0.47751124 2.145275 5.0003414 0.01
6600 1.0681827 21.318359 3.3146529 0.67959676
0.45927675 2.1757794 4.9168888 0.01
6700 1.0841398 21.373696 3.334401 0.67823091
0.47134607 2.184824 4.960572 0.01
6800 1.0663954 21.453016 3.2887075 0.64916505
0.45130369 2.1882388 4.8882625 0.01
6900 1.1452508 21.420367 3.2686679 0.68711011
0.45067579 2.130882 4.9865032 0.01
7000 1.1127547 21.269785 3.2826127 0.69260739
0.46066263 2.1293427 4.951705 0.01
7100 1.5097478 22.533366 3.3207702 0.77042922
0.43797242 2.1123685 5.585338 0.01
2. run 7000 steps,
the next 1000 steps
7000 1.1127547 21.0987 3.2826127 0.69260739
7100 1.1676093 21.290735 3.3215576 0.74106337
0.45072515 2.1297691 5.0729299 0.01
7200 1.1909944 21.084995 3.2404307 0.75245499
0.44470009 2.0432756 5.0268798 0.01
7300 1.0443722 20.694148 3.2322305 0.71750029
0.44304914 2.0716811 4.7987516 0.01
7400 1.3378401 21.61837 3.199652 0.7498716
0.43366541 2.016115 5.2063644 0.01
Comparing those two outputs, we can see the difference starts at the
time step 7100. Could anyone tell me what is going on when the
simulation continued at the timestep 7000? Thank you in advance.
Dongsheng
