Hi all,
I’m a relatively new LAMMPS user who is trying to connect LAMMPS with the phonolammps python tool. I’ve run into some difficulties with getting the shared libraries connected, so I am testing everything out on the google colab for ease of sharing / to have a clean slate.
- I have installed LAMMPS (10 Mar 2021)
- I aim to run lammps with the USER-MEAMC package along with phonolammps
- As stated above, I am currently in the google colab setup. I download and install lammps using the -DCMAKE_INSTALL_PREFIX to give the complete (no ~) location that matches my LD_LIBRARY_PATH
- Upon running the following command:
!D_LIBRARY_PATH="$LD_LIBRARY_PATH" ldd which lmp
I get the following output
linux-vdso.so.1 (0x00007fff33bd4000) /usr/lib/x86_64-linux-gnu/libtcmalloc.so.4 (0x00007f5f5ac63000) liblammps.so.0 => /usr/local/nvidia/lib/liblammps.so.0 (0x00007f5f5a478000) libmpi_cxx.so.20 => /usr/lib/x86_64-linux-gnu/libmpi_cxx.so.20 (0x00007f5f5a25e000) libmpi.so.20 => /usr/lib/x86_64-linux-gnu/libmpi.so.20 (0x00007f5f59f6c000) libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f5f59be3000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f5f599cb000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f5f595da000) libunwind.so.8 => /usr/lib/x86_64-linux-gnu/libunwind.so.8 (0x00007f5f593bf000) libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f5f591a0000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f5f58e02000) libjpeg.so.8 => /usr/lib/x86_64-linux-gnu/libjpeg.so.8 (0x00007f5f58b9a000) libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f5f58968000) libgomp.so.1 => /usr/lib/x86_64-linux-gnu/libgomp.so.1 (0x00007f5f58739000) libopen-rte.so.20 => /usr/lib/x86_64-linux-gnu/libopen-rte.so.20 (0x00007f5f584b1000) libopen-pal.so.20 => /usr/lib/x86_64-linux-gnu/libopen-pal.so.20 (0x00007f5f581ff000) librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f5f57ff7000) libhwloc.so.5 => /usr/lib/x86_64-linux-gnu/libhwloc.so.5 (0x00007f5f57dba000) /lib64/ld-linux-x86-64.so.2 (0x00007f5f5b0e7000) liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f5f57b94000) libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f5f57977000) libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f5f57773000) libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f5f57570000) libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007f5f57365000) libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7 (0x00007f5f5715b000)
which leads me to believe that everything is okay (because there are no “not found” messages here)
However, when I try running a test phonolammps run, it claims that liblammps.so is not found. I apologize if this is a silly question at all, but I’m hoping there’s a simple explanation as to what I am doing wrong. Upon browsing through lammps documentation and the answers to a related question I may be confused about where, ideally, liblammps.so is supposed to live.
If it is helpful, I would be glad to share my google colab document so people may see my full installation steps.
Thank you, and have a great day,
-AJ
