I am having a lot of difficulty adding a molecule to an already-existing simulation. I have tried my best to read the documentation and follow examples. I have also done this before succesfully with a more simple molecule (hydrogen gas), so I am perplexed with the current problems.
I am running the 7 Aug 2019 version of LAMMPS; I’d like to keep this version since that’s what I used for the previous simulations but I could change if needed. I get the same error from the 3 March 2020 version.
I am trying to add a molecule to, e.g., a box of water. I first run a short simulation on the box of water, with no problems. Then I use a molecule template to add 1 molecule at random into the box. I get a warning and an error:
WARNING: Molecule attributes do not match system attributes (../molecule.cpp:1386)
ERROR: Molecule topology/atom exceeds system topology/atom (../molecule.cpp:1415)
I have specified the needed number of extra types, bonds, angles, etc. I have tried doing this in various ways. I don’t seem to succeed in any case. I have attached my molecule template and input script below.
Amalie
Here’s the molecule file:
Zincate
9 atoms
8 bonds
10 angles
Coords
1 -1.603907 1.211837 -0.272400
2 -2.219043 0.545670 0.077819
3 -0.015670 0.068918 -0.020661
4 -0.707721 -1.625115 0.801466
5 -0.391026 -2.153992 0.049244
6 0.932809 -0.511747 -1.667599
7 1.807081 -0.231367 -1.348724
8 1.412678 0.761188 1.181746
9 1.259616 0.068276 1.846429
Types
1 3
2 4
3 5
4 2
5 3
6 2
7 3
8 2
9 3
Charges
1 -1.0027
2 0.2838
3 0.8756
4 -1.0027
5 0.2838
6 -1.0027
7 0.2838
8 -1.0027
9 0.2838
Masses
1 15.9994
2 1.0078
3 65.4
4 15.9994
5 1.0078
6 15.9994
7 1.0078
8 15.9994
9 1.0078
Bonds
1 1 1 2
2 2 1 3
3 2 3 4
4 2 3 6
5 2 3 8
6 1 4 5
7 1 6 7
8 1 8 9
Angles
1 1 2 1 3
2 1 5 3 4
3 1 7 3 6
4 1 9 3 8
5 2 1 3 4
6 2 1 3 6
7 2 1 3 8
8 2 4 3 6
9 2 4 3 8
10 2 6 3 8
Here’s the lammps input file; the data file is just a simple box of water.
Variable definitions
variable project index “wat”
Initialization
units real
atom_style full
pair_style lj/cut/coul/long 10.0 10.0
bond_style harmonic
angle_style harmonic
dihedral_style opls
special_bonds lj/coul 0.0 0.0 0.5 dihedral no
System
read_data water.data extra/atom/types 3 extra/bond/types 2 extra/angle/types 2 extra/special/per/atom 20
pair_modify tail no
kspace_style pppm 1.e-4
mass 3 15.999
mass 4 1.0078
mass 5 65.4
pair_coeff 1 1 0.1554 3.16557 # ow, ow
pair_coeff 1 2 0.0 2.0614 # ow, hw
pair_coeff 2 2 0.0 0.9572 # hw, hw
pair_coeff 3 3 0.2104 3.0664 # amber
pair_coeff 4 4 0.0 0.0
pair_coeff 5 5 0.0007549 2.0989 # amber
Bond Coeffs
bond_coeff 1 600.00000 0.95720 # ow4,hw
bond_coeff 2 700 1.0
bond_coeff 3 700 1.96
Angle Coeffs
angle_coeff 1 75.00000 109.50000 # hw,ow4,hw
angle_coeff 2 1000 94.19
angle_coeff 3 1000 109.47
variable TK equal 300.0
variable PBAR equal 1.0
group wat type 1 2
Settings
neighbor 1.0 bin
velocity all create 300 3189434 dist gaussian rot yes mom yes sum yes
timestep 1.0
thermo_style custom step temp pe etotal press vol density
thermo 500
thermo_modify flush yes
keep water rigid
fix watsh wat shake 0.0001 20 0 b 1 a 1
fix TPSTAT all npt temp {TK} {TK} 100 iso {PBAR} {PBAR} 1000
dump TRAJ all custom 20000 wat.lammpstrj id mol type element x y z ix iy iz
restart 1000000 wat.rst
run 1000
add zincate
molecule zincate zincate.template toff 0 boff 1 aoff 1
region cell block EDGE EDGE EDGE EDGE EDGE EDGE
create_atoms 0 random 1 225698 cell mol zincate 13546
run 10000
write_restart restart.*.lmp
write_data data.*.lmp
