Hi Sandip,
I think you should use these commands:
fix 1 left_atoms setforce 0.0 0.0 0.0
fix 2 left_atoms aveforce -1.0 0.0 0.0
fix 3 right_atoms setforce 0.0 0.0 0.0
fix 4 right_atoms aveforce 1.0 0.0 0.0
because the first command sets all forces on left atoms to zero and then
the second command applies the force to the group of atoms in such a way
that every atom experiences the same force.
Ali
Message: 1
Date: Fri, 29 Feb 2008 22:30:22 +0530
Subject: [lammps-users] direction in setforce command
To: <[email protected]>
Message-ID:
<[email protected]...>
Content-Type: text/plain; charset="iso-8859-1"Hi all,
I needed little clarification of the command. If I use setforce to push
few atoms in which direction will they be pushed.I have a domain X= -l to l with a hole at X=0. I want to push the right
side atoms to +X direction and left side atoms to -X direction. I am
using:fix 1 left_atoms setforce -1.0 0 0
fix 2 right_atoms setforce 1.0 0 0Is this ok or there is any better command?
Thanks in advance,
Sandip Haldar--
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.-------------- next part --------------
An HTML attachment was scrubbed...------------------------------
Message: 2
Date: Fri, 29 Feb 2008 10:57:29 -0600
Subject: [lammps-users] Parallel Replica Dynamics w/ LAMMPS?
To: LAMMPS user list <[email protected]>
Message-ID: <[email protected]...>
Content-Type: text/plain; charset="us-ascii"Hi All,
I am curious if anyone on the list has tried to set up a parallel
replica dynamics (accelerated MD method developed by Art Voter of LLNL
and coworkers) run using LAMMPS as a base. It is essentially running a
group of nearly identical simulations in parallel, with periodic
communications between them.One of the things that is needed for PRD to work is a sort of
'wrapper' which will allow for the creation of the replicas and
starting the simulations, allow the replicas to communicate if a
transition has been detected in one of the replicas, and if so, to
stop all the others, then communicate the state of the replica that
had the transition to the other replicas(perhaps create some output),
and repeat the process.Add added complexity will come in the fact that I will have to deal
with a batch scheduler system too, because I am using an HPC center
machine.Anyone ever try anything like this?
Dave
David E. Farrell
Graduate Student
Mechanical Engineering
Northwestern University
email: [email protected]...-------------- next part --------------
This SF.net email is sponsored by: Microsoft
Defy all challenges. Microsoft(R) Visual Studio 2008.
http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/------------------------------
_______________________________________________
lammps-users mailing list
[email protected]
https://lists.sourceforge.net/lists/listinfo/lammps-usersEnd of lammps-users Digest, Vol 21, Issue 54
Ali Rajabpour
Department of Mechanical Engineering,
University of Tehran,
P.O. Box 14395-515
Tel: +98 21 61114827
Email: [email protected]...
Personal Homepage (In Farsi) : www.Rajabpour.ir
