Dear Lammps users.
I have a equilibrated cubic system and I want to build a new system with twice of its size (volume) and cubic. So I thought of replicated the original system in one of the dimension and then using fix_deform/displace_box command to make it cubic (almost).
While I tried to use both fix_deform and displace_box command, it doesn’t seem to work out.
With displace_box
I used
fix 1 all npt 300 300 100 aniso 1 1 1 1 1 1 100 drag 0.5
displace_box all z scale 0.63 x volume y volume units box
Here, it seems that in the first step only, it reduces the box to final dimensions and then bring them back to original (initial) one in the later steps.
Should I use displace_box with another fix? I did not find any information (for what fix I can use) in the manual.
With fix deform
With fix_deform, I tried using all fixes (nve, npt, nvt) but the simulation is crashing everytime with following error messages
npt
fix 2 all deform 10 z scale 0.63 x volume y volume units box
Here, I get after 10 steps, volume = 0.0 and compute of out of range error : PPPM
nvt/nve
fix 1 all (nve/nvt fix)
Here, I get after 10 steps, volume = 0.0 and Error: Cannot use neighbor bins - box size << cutoff.
I am not sure where I am doing things wrong.
In this case also, what fix should I use to calculate forces/positions/velocities of the atoms.
Any help would be highly appreciated.
