I am trying to simulate a simple LJ system. How can I eliminate the
neighbor list and any other tricks used in LAMMPS?
Any help would be appreciated.
Regards,
Ali
Regards,
Ali
ali,
if you don't want the "tricks" in LAMMPS, don't use LAMMPS.
a "simple" LJ code can be written very easily. check out
your favorite text book on MD. basically all of them have
examples on how to do it. mind you the _physics_ will be
the same. the "tricks" in LAMMPS only help to execute it
faster and in parallel.
cheers,
Axel,
I know the tricks help to execute LAMMPS faster but this is not true all
the time. For example, when the dump command writes the positions in a
file, some atoms go slightly outside the simulation box because the
neighbor lists are rebuilt. It is important to fix this problem for
calculating heat flux by using of Green-Kubo method. I am trying to know
how I can use LAMMPS without neighbor list. Can I set the skin parameters
equal to a large value and set the delay parameters to a large number for
building only a big neighbor list?
Axel,
this is a postprocessing problem. just rewrap your coordinates
_after_ the simulation and before your analysis and you are fine.
no need to sacrifice performance.
of course you can also reneighbor in every step. see neigh_modify.
The dump file has nothing to do with neighbor lists. Neighbor
lists are internal to LAMMPS; you don't see their effect in output.
