I have no clue on defining the energy keyword for the way that I am using fix addforce below for fixes 3 & 4. Any help is greatly appreciated.
fix 1 UpperFixed store/force
fix 2 LowerFixed store/force
compute ufzc UpperFixed reduce ave f_1[3]
compute lfzc LowerFixed reduce ave f_2[3]
variable avg_velocityZ_up equal vcm(UpperFixed,z)
variable avg_velocityZ_low equal vcm(LowerFixed,z)
variable vz_init_upper equal -v_avg_velocityZ_up
variable vz_init_lower equal -v_avg_velocityZ_low
velocity UpperFixed set 0 0 v_vz_init_upper sum yes units box
velocity LowerFixed set 0 0 v_vz_init_lower sum yes units box
variable appforceZ1 equal -c_ufzc
variable appforceZ2 equal -c_lfzc
fix 3 UpperFixed addforce 0 0 v_appforceZ1 energy ???
fix_modify 3 virial yes energy yes
fix 4 LowerFixed addforce 0 0 v_appforceZ2 energy ???
fix_modify 4 virial yes energy yes
fix 5 all npt/cauchy temp {TempHi} {TempHi} (100.0 * dt) &
x 0.0 0.0 (1000.0 * dt) y 0.0 0.0 $(1000.0 * dt) couple none tchain 5 tloop 100 pchain 5 ploop 100 nreset 1000 alpha 0.001
fix_modify 5 temp TempNVT press Press
fix 7 all dt/reset 1 NULL NULL ${MaxDist} units box
fix 8 all balance 2500 1.0 shift xyz 10 1.0 weight time 0.8
fix 9 all momentum 1000 linear 1 1 1 #angular
run 100000 post no
It looks like you are computing an average force and applying that as a variable with fix addforce.
There is no way I see to specify the energy variable for that needed for minimization.
Why not just use fix aveforce instead? It can work with minimization as-is. No need for a variable.
Steve,
One last question on this fix.
Do you think it is necessary to modify fixes 3 and 4 like below?
fix 5 all npt/cauchy temp 300 300 (100.0 * dt) &
fix 7 all dt/reset 1 NULL NULL 0.02 units box
run 100000 post no
The fix addforce doc page explains what those 2 modify options do. It’s up to you.
Try a modify option both ways to see the difference.
