Hi Steve,
Thank you for your reply. I am still not sure how to do the energy minimization without dynamics. As you suggested, I did the example indent problem in LAMMPS, and only use minimize after each fix command. But I think the results are not correct. The minimization only has one iteration in each step, and the lattice was not affected by the indenter. So that’s why I always use run before the minimize command. The input script is like this:
2d indenter simulation
dimension 2
boundary p s p
atom_style atomic
neighbor 0.3 bin
neigh_modify delay 5
create geometry
lattice hex 0.9
region box block 0 20 0 10 -0.25 0.25
create_box 2 box
create_atoms 1
mass 1 1.0
mass 2 1.0
LJ potentials
pair_style lj/cut 2.5
pair_coeff * * 1.0 1.0 2.5
define groups
region 1 block INF INF INF 1.25 INF INF
group lower region 1
group mobile subtract all lower
set lower atom 2
initial velocities
fix 2 lower setforce 0.0 0.0 0.0
indenter
fix 4 all indent 1000.0 sphere 10 13 0 5.0
fix 5 all enforce2d
Run with indent
thermo 1
dump 1 all atom 1 tmp.dump
minimize 1.0e-4 1000 1000
fix 4 all indent 1000.0 sphere 10 12 0 5.0
dump_modify 1 every 1
fix 4 all indent 1000.0 sphere 10 11.8 0 5.0
fix 4 all indent 1000.0 sphere 10 11.6 0 5.0
fix 4 all indent 1000.0 sphere 10 11.4 0 5.0
fix 4 all indent 1000.0 sphere 10 11.2 0 5.0
fix 4 all indent 1000.0 sphere 10 11.0 0 5.0
fix 4 all indent 1000.0 sphere 10 10.8 0 5.0
fix 4 all indent 1000.0 sphere 10 10.6 0 5.0
fix 4 all indent 1000.0 sphere 10 10.4 0 5.0
fix 4 all indent 1000.0 sphere 10 10.2 0 5.0
If you think somewhere is wrong, could you give me some suggestions? Thanks a lot!
Yours,
Jie Lian
