Hi!
The error I describe here concerns the basic things, so it seems very strange.
First, a "formal" part. My system is GNU/Linux Fedora 6. LAMMPS of
February 08, 2008 was compiled with g++ with stub MPI, without FFT
library and also without any optional packages (just default set). No
compiler optimization keys were used.
Next, the problem.
Let us calculate with LAMMPS the non-bonded energies in two simplistic systems.
Each system comprises just two equal atoms in periodic box. The atoms
have charges +1 and -1.
The systems differ in that in the first one there are no chemical
bonds whereas in the second one the two atoms are connected with a
bond.
Here are the input files for the above systems:
1)"non-bonded system"
===== in.AA =====
units real
atom_style full
special_bonds 0.0 0.0 0.0
kspace_style ewald 0.00001
pair_style lj/cut/coul/long 12.0
read_data data.AA
thermo_style custom pe evdwl ecoul elong
thermo 1000
run 0
===== end of in.AA ====
===== data.AA =====
2 atoms
1 atom types
0.0000 4.0000 xlo xhi
0.0000 4.0000 ylo yhi
0.0000 8.0000 zlo zhi
Masses
1 1.0000
Pair Coeffs
1 1.0000 4.0000
Atoms
1 1 1 -1.0000 2.0000 2.0000 2.0000
2 1 1 1.0000 2.0000 2.0000 6.0000
===== end of data.AA ====
2) "bonded system"
===== in.A-A =====
units real
atom_style full
bond_style harmonic
read_data data.A-A
thermo_style custom pe evdwl ecoul elong ebond
thermo 1000
run 0
===== end of in.A-A ====
===== data.A-A =====
2 atoms
1 bonds
1 atom types
1 bond types
Masses
1 1.0000
Pair Coeffs
1 1.0000 4.0000
Bond Coeffs
1 100.0000 4.0000
Atoms
Bonds
1 1 1 2
Now let us see the results (only energies here; full log.lammps files
see in attachment).
For the "non-bonded system" we have:
PotEng E_vdwl E_coul E_long
-72.347992 -8.0582398 11.535252 -75.825004
These values are correct; I've reproduced them in MatLab with good accuracy.
Now let's predict the Coulomb and van der Waals energies for "bonded system".
They should differ from the above values by energies of corresponding
interactions between bonded atoms.
For van der Waals this energy is zero. So E_vdwl should remain -8.0582398.
For Coulomb this energy is 332.063709 * 1 * (-1) / 4.0 = -83.015927.
So E_coul should become 94.551179 kcal/mol. (E_long should not differ)
Now let us see the LAMMPS output:
PotEng E_vdwl E_coul E_long E_bond
1791.1817 -2.8680738 1869.8748 -75.825004 0
Now the question: WHAT'S WRONG ?
Am I missing something or it's a bug?
Vadim
PS: The same behavior takes place with ewald/n solver with pair_style
lj/coul long long 12.0 (when LAMMPS is built with optional package
USER-EWALDN)
log.lammps.AA (1.18 KB)
log.lammps.A-A (1.26 KB)
