Hi all,
I am trying to build the dec 04 release on my G4 mac w/ 10.5.1 using the same makefile I used in the 5Oct07 release (which was for serial execution without the FFT stuff), but am running into some errors which appear to be related to the MPI libs… and I did build the MPI dummy files in the STUBS directory:
Undefined symbols:
“MPI_Recv(void*, int, int, int, int, int, MPI_Status*)”, referenced from:
LAMMPS_NS::Comm::irregular_create(int, int*, int*, int*)in comm.o
LAMMPS_NS::Dump::write() in dump.o
LAMMPS_NS::Temper::command(int, char**)in temper.o
LAMMPS_NS::WriteRestart::write(char*) in write_restart.o
“MPI_Wtime()”, referenced from:
LAMMPS_NS::PPPM::timing(int, double&, double&)in pppm.o
LAMMPS_NS::stamp() in timer.o
LAMMPS_NS::stamp(int) in timer.o
LAMMPS_NS::barrier_start(int) in timer.o
LAMMPS_NS::barrier_stop(int) in timer.o
LAMMPS_NS::elapsed(int) in timer.o
“MPI_Cart_get(int, int, int*, int*, int*)”, referenced from:
LAMMPS_NS::Comm::set_procs() in comm.o
“MPI_Waitany(int, int*, int*, MPI_Status*)”, referenced from:
remap_3d(double*, double*, double*, remap_plan_3d*)in remap.o
“MPI_Cart_create(int, int, int*, int*, int, int*)”, referenced from:
“MPI_Sendrecv(void*, int, int, int, int, void*, int, int, int, int, int, MPI_Status*)”, referenced from:
LAMMPS_NS::Comm::borders() in comm.o
LAMMPS_NS::Comm::exchange() in comm.o
and it goes on from there, but this is the top of the list.
Any ideas?
Dave
David E. Farrell
Graduate Student
Mechanical Engineering
Northwestern University
email: d-farrell2@…12…435…
