hello,everyone,this is rufer,when I compile lammps in ubuntu, error message comes as follows:
…/domain_omp.cpp:37:6: error: ‘DomainOMP’ has not been declared
37 | void DomainOMP::pbc()
…/domain_omp.cpp: In function ‘void pbc()’:
…/domain_omp.cpp:39:42: error: ‘atom’ was not declared in this scope; did you mean ‘atol’?
39 | dbl3_t * _noalias const x = (dbl3_t *)&atom->x[0][0];
atol
…/domain_omp.cpp:41:43: error: ‘triclinic’ was not declared in this scope
41 | const double * _noalias const lo = (triclinic == 0) ? boxlo : boxlo_lamda;
…/domain_omp.cpp:41:61: error: ‘boxlo’ was not declared in this scope
…/domain_omp.cpp:41:69: error: ‘boxlo_lamda’ was not declared in this scope
…/domain_omp.cpp:42:61: error: ‘boxhi’ was not declared in this scope
42 | const double * _noalias const hi = (triclinic == 0) ? boxhi : boxhi_lamda;
…/domain_omp.cpp:42:69: error: ‘boxhi_lamda’ was not declared in this scope
…/domain_omp.cpp:43:61: error: ‘prd’ was not declared in this scope
43 | const double * _noalias const period = (triclinic == 0) ? prd : prd_lamda;
…/domain_omp.cpp:43:69: error: ‘prd_lamda’ was not declared in this scope
…/domain_omp.cpp:54:9: error: ‘xperiodic’ was not declared in this scope; did you mean ‘period’?
54 | if (xperiodic) {
period
…/domain_omp.cpp:57:13: error: ‘deform_vremap’ was not declared in this scope
57 | if (deform_vremap && mask[i] & deform_groupbit) v[i].x += h_rate[0];
…/domain_omp.cpp:57:40: error: ‘deform_groupbit’ was not declared in this scope
…/domain_omp.cpp:57:67: error: ‘h_rate’ was not declared in this scope
…/domain_omp.cpp:67:13: error: ‘deform_vremap’ was not declared in this scope
67 | if (deform_vremap && mask[i] & deform_groupbit) v[i].x -= h_rate[0];
…/domain_omp.cpp:67:40: error: ‘deform_groupbit’ was not declared in this scope
…/domain_omp.cpp:67:67: error: ‘h_rate’ was not declared in this scope
…/domain_omp.cpp:76:9: error: ‘yperiodic’ was not declared in this scope; did you mean ‘period’?
76 | if (yperiodic) {
period
…/domain_omp.cpp:79:13: error: ‘deform_vremap’ was not declared in this scope
79 | if (deform_vremap && mask[i] & deform_groupbit) {
…/domain_omp.cpp:79:40: error: ‘deform_groupbit’ was not declared in this scope
…/domain_omp.cpp:80:21: error: ‘h_rate’ was not declared in this scope
80 | v[i].x += h_rate[5];
…/domain_omp.cpp:92:13: error: ‘deform_vremap’ was not declared in this scope
92 | if (deform_vremap && mask[i] & deform_groupbit) {
…/domain_omp.cpp:92:40: error: ‘deform_groupbit’ was not declared in this scope
…/domain_omp.cpp:93:21: error: ‘h_rate’ was not declared in this scope
93 | v[i].x -= h_rate[5];
…/domain_omp.cpp:104:9: error: ‘zperiodic’ was not declared in this scope; did you mean ‘period’?
104 | if (zperiodic) {
period
…/domain_omp.cpp:107:13: error: ‘deform_vremap’ was not declared in this scope
107 | if (deform_vremap && mask[i] & deform_groupbit) {
…/domain_omp.cpp:107:40: error: ‘deform_groupbit’ was not declared in this scope
…/domain_omp.cpp:108:21: error: ‘h_rate’ was not declared in this scope
108 | v[i].x += h_rate[4];
…/domain_omp.cpp:121:13: error: ‘deform_vremap’ was not declared in this scope
121 | if (deform_vremap && mask[i] & deform_groupbit) {
…/domain_omp.cpp:121:40: error: ‘deform_groupbit’ was not declared in this scope
…/domain_omp.cpp:122:21: error: ‘h_rate’ was not declared in this scope
122 | v[i].x -= h_rate[4];
…/domain_omp.cpp: At global scope:
…/domain_omp.cpp:141:6: error: ‘DomainOMP’ has not been declared
141 | void DomainOMP::lamda2x(int n)
…/domain_omp.cpp: In function ‘void lamda2x(int)’:
…/domain_omp.cpp:143:42: error: ‘atom’ was not declared in this scope; did you mean ‘atol’?
143 | dbl3_t * _noalias const x = (dbl3_t *)&atom->x[0][0];
atol
…/domain_omp.cpp:150:14: error: ‘h’ was not declared in this scope
150 | x[i].x = h[0]*x[i].x + h[5]*x[i].y + h[4]*x[i].z + boxlo[0];
…/domain_omp.cpp:150:56: error: ‘boxlo’ was not declared in this scope
…/domain_omp.cpp:161:6: error: ‘DomainOMP’ has not been declared
161 | void DomainOMP::x2lamda(int n)
…/domain_omp.cpp: In function ‘void x2lamda(int)’:
…/domain_omp.cpp:163:42: error: ‘atom’ was not declared in this scope; did you mean ‘atol’?
163 | dbl3_t * _noalias const x = (dbl3_t *)&atom->x[0][0];
atol
…/domain_omp.cpp:170:30: error: ‘boxlo’ was not declared in this scope
170 | double delta0 = x[i].x - boxlo[0];
…/domain_omp.cpp:174:14: error: ‘h_inv’ was not declared in this scope
174 | x[i].x = h_inv[0]*delta0 + h_inv[5]*delta1 + h_inv[4]*delta2;
make[1]: *** [Makefile:113: domain_omp.o] Error 1
make[1]: Leaving directory ‘/home/rufer/Documents/lammps-stable/lammps-29Oct20/src/Obj_ubuntu’
make: *** [Makefile:212: ubuntu] Error 2
any advice will be appreatiate.
