[lammps-users] ERROR: Non-numeric pressure - simulation unstable
Dear Lammps users,
I want to relax the wurtzite structure by SW polymorphic potentiel , but when I try to do simulation with Lammps, I got an error.
I have attached the input data and the code for relaxation.
LAMMPS (29 Sep 2021 - Update 1)
relaxation for lattice constant
P1 Initialization basic condition
#package omp 0 neigh yes # Nthreads=0 for default value set by OMP_NUM_THREADS environment
#how MPI tasks are mapped to the simulation box
processors * * *
atom_style atomic
#atom_modify
P2 setup box and create atoms and groupen atoms
read struct.data
read_data perfectwz.data
Reading data file …
orthogonal box = (-1.1275740 0.0000000 0.0000000) to (13.530880 10.416080 8.7716640)
5 by 4 by 2 MPI processor grid
reading atoms …
420 atoms
read_data CPU = 0.009 seconds
neighbor 2.0 bin
P3 Potential config: Pair style for atomic interactions
pair_style polymorphic
pair_coeff * * GaN_sw.poly N Ga
Reading polymorphic potential file GaN_sw.poly with DATE: 2015-12-09
#pair_style sw
#pair_coeff * * GaN.sw N Ga
P4 Define and initialize atomic configuration
fix F1 all box/relax aniso 0 vmax 0.01 fixedpoint 0 0 0
P4 Fixes for time integration and constraints
thermo 1
thermo_style custom step press etotal vol lx ly lz
compute atmE all pe/atom
dump D1 all custom 100 rlx_struct.dump.* id type x y z fx fy fz c_atmE
P5 Run or minimize
min_style cg
minimize 1.0e-15 1.0e-15 1000 10000
Neighbor list info …
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 5.36
ghost atom cutoff = 5.36
binsize = 2.68, bins = 6 4 4
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair polymorphic, perpetual
attributes: full, newton on
pair build: full/bin/atomonly
stencil: full/bin/3d
bin: standard
Per MPI rank memory allocation (min/avg/max) = 5.611 | 5.617 | 5.621 Mbytes
Step Press TotEng Volume Lx Ly Lz
0 -nan -nan 1339.2895 14.658454 10.41608 8.771664
ERROR: Non-numeric pressure - simulation unstable (…/fix_box_relax.cpp:732)
Last command: minimize 1.0e-15 1.0e-15 1000 10000
in.LattCont (1.15 KB)
perfectwz.data (13 KB)
Most likely your initial geometry is incorrect leading to overlapping atom positions.
Have you visualized it and also checked whether there are no overlaps through periodic boundaries?
You can also do a simple check in your input. If you add a command like:
delete_atoms overlap 0.1 all all
There should be no atoms deleted. If there are, your data file has a bad geometry.
