Dear lampps community,
my version of lampps is 07-Apr-2010, so it's the latest stable release right now. I am facing the following problem: The output file created with the command:
fix_modify AtC transfer output [name] [frequency] tensor_components
from the atc-package crashes the visualization software Paraview.
The version of Paraview I'm using is the latest stable release: 3.8.0. I tried this one on an i386 and a x86 linux architecture, both have the same problem. I attached 1 output file from the atc example simulation bar1d_ttm to this e-mail for anybody who would like to try it himself. In the input file I simply added the command mentioned above. It is possible to open the file, but when going to the next frame I get the following output and Paraview crashes:
ERROR: In /home/kitware/ParaView-3-8/ParaView-3.8/ParaView/Servers/Filters/vtkEnSightReader2.cxx, line 308
vtkEnSightGoldBinaryReader2 (0x8da1cb0): error reading geometry file
ERROR: In /home/kitware/ParaView-3-8/ParaView-3.8/ParaView/VTK/Filtering/vtkExecutive.cxx, line 757
vtkCompositeDataPipeline (0x8d92b80): Algorithm vtkEnSightGoldBinaryReader2(0x8da1cb0) returned failure for request: vtkInformation (0x8cbec88)
Debug: Off
Modified Time: 128298
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
FROM_OUTPUT_PORT: 0
I'm not sure whether this is an error of the output file or from Paraview. So I wrote an e-mail to the developers of Paraview, too. In case I get a response, I will add it here. Does anybody in this community have an idea how to solve this problem?.
Thanks for your suggestions in advance.
Sincerely Yours
M.Busse
Simulation1.rar (28.8 KB)
