I am using the latest version of LAMMPS (11-May10) and am having troubles with the fix addforce command.
My syntax is as follows:
fix A_field A addforce 0.0 0.0 0.3
This is essentially the same as the example syntax provided for the “fix addforce” command so I think I may be encountering a bug.
The error message I am receiving is:
ERROR: Cannot use variable energy with constant force in fix addforce
(I could not find any information on this in the LAMMPS errors section.)
Please let me know where I am going wrong or if more information is required for help on this issue.
Thanks as always,
Brian
