[lammps-users] fix box/relax command
I’d like to perform geometric optimization permitting the change of cell size.
It is written that fix box/relax command should be used but I don’t know whether it is given with minimize command or it is enough standalone.
I use minimize command and then fix box/relax command but it results in no change from initial box size and it seems that it didn’t operate correctly.
My input is as follows briefly.
2011/3/21 JhonY. I. <[email protected]...>:
I'd like to perform geometric optimization permitting the change of cell
size.
It is written that fix box/relax command should be used but I don't know
change from initial box size and it seems that it didn't operate correctly.
the "minimize" command is very similar to "run"
if you want a "fix" to be active, you have to define it
_before_ you call minimize. order matters in a lammps input script.
