Hi. Is the original configuration of a system stored in restart files? That is, if you are doing a run with fix msd, stop it, and restart it from a restart file, will the MSD pick up where it left off or will it revert to zero?
Rob
Rob
HI Rob.
Yes, it is stored in the restart file. So it picks up where it left off as long as you use the same fix ID and haven’t issued an “unfix” command. It is easy to tell when LAMMPS is picking up where it left off because you’ll see a message like this:
Resetting per-atom state of Fix 2 Style msd from restart file info
Paul
Rob
