I am attempting to simulate self diffusion of various gases in a flexible solid in the NVT ensemble by measuring the MSD. Eventually, I would like to simulate nitrogen (n2) as 2 atomic sites and 3 point charges with one charge on each atomic site and the third on the center of mass (represented as a massless particle with LJ eps and sigma = 0), similar to a previous thread (http://lammps.sandia.gov/threads/msg15533.html) which requires the use of fix rigid. However, using the test case of CO2, the use of “fix rigid/nvt” gives results that are inconsistent (and look incorrect) as compared to “fix nvt” . The fix nvt results are similar to what is observed for single LJ center gases and the results make sense.
The fixes used in each simulation are as follows:
fix 1 all nvt temp 293.15 293.15 100
and:
fix 1 solid nvt temp 293.15 293.15 100
fix 2 gas rigid/nvt molecule temp 293.15 293.15 100
Am I using fix rigid/nvt incorrectly? I need to use fix rigid/nvt for N2 and would like to use it for CO2 as well, to be consistent with other simulations and to reduce degrees of freedom and increase simulation speed.
-Greg
