In fix spring command, the point to which spring is tethered is fixed
if "tether" is chosen.
Do you know how to let the point move, i.e., its coordinates can
change in a specified manner
(for example, moving along a vector in a given speed)?
Thanks a lot!
Yong
Yong,
No, the current version of fix spring can't be used in
the manner you wish. But you could modify it without
too much difficulty to get it to do what you want. You
might also look at fix lineforce:
http://www.cs.sandia.gov/~sjplimp/lammps/doc/fix_lineforce.html
which may be adequate for what you want.
Paul
Dear list
i am using fix rdf command for finding the "g" value at contact
when i used the command like shown below
{fix 6 active rdf 50 rdf.out 6000 1 1} , i am getting huge values
for the flow on inclined plane (granular systems)
example : angle of inclination :25 degrees
g(0.999929) = 179.0176 (when i put kn=200000 and gamman =
57.5)
actually for crystalline systems we can expect a value of aroung 70 to 80
can somebody clear my doubts if you have used this command?
regards
anki
I've never used rdf with granular systems, but I don't
know any reason it shouldn't work. You might look
in the fix_rdf.cpp file and make sure the normalizations
look correct for the system you are running. You could
add some instrumentation to print out raw counts and
see if you are getting numbers you expect.
Paul, Thanks!
Actually, I can get what I want in an alternative way. That is to let
a group of atoms move
along a vector in a given constant speed without making the group of
atoms rigid.
Do you think LAMMPS can do this?
Thanks!
Yong
Yong,
LAMMPS has several fixes that impose forces to groups
of atoms, but I don't see any that will set the
velocity of a group to a constant vector. Perhaps you
could use fix drag:
http://www.cs.sandia.gov/~sjplimp/lammps/doc/fix_drag.html
to apply a set force to your group of atoms.
Paul
Paul, Thanks!
way. That is to let
making the group of
atoms rigid.
Thanks!
Yong
> Yong,
used in
without
You
You can set the initial velocity of a group of atoms
to some value, then turn off the forces, and they
will continue to move with v. However that
is like they are moving as a rigid body.
