Hi all,
Lammps manual tells that, fix ttm can be used to model the heat transfer between electronic and atomic subsystem. I want some literatures other than the two references provided in that page. Those two references gives basic algorithm which has been used in this fix command. Is somebody used this command and familiar with how to define continuum model of electronic subsystem? give me help.
thanking you.
with regards
Angela
