[lammps-users] GPUs on multiple nodes:
Manish Agarwal
<[email protected]...>
Postdoctoral Research Scientist
Chemical Engineering
Columbia University
Axel,
Indeed, I do need to read the documentation again, however:
The first place I came across this is :
http://lammps.sandia.gov/workshops/Feb10/Mike_Brown/gpu_tut.pdf
Also given in lammps manual (attached: 36,37.pdf) Page number 25 (36 of 779)
and in pair_lj.html (attached) given in the doc of the tarball.
My question should have been : Is it possible to run GPU accelerated
LAMMPS on multiple nodes with a CPU each? If yes, how?
As usual, expecting miracles from you !
Manish Agarwal
Columbia University
pair_lj.html (12.2 KB)
36,37.pdf (28.8 KB)
manish,
Axel,
yes!
LAMMPS Molecular Dynamics Simulator
but that is almost a year old!!
the gpu code has been updated more than once since.
please use an up-to-date version.
yes, it is possible and it can be quite fast:
http://sites.google.com/site/akohlmey/software/lammps-benchmarks
it is in the documentation. you must have read it,
since your single node input was in accord with the
current documentation, but conflicting the documentation
that you are quoting and attaching.
i am still working on inventing the "remote cluebat"
GPU tutorial now too old.
pair_lj had some old text left in. this is fixed in current on-line docs.
Read running on GPUs in section_start to get current instructions
Paper on gpu methods here:
http://dx.doi.org/10.1016/j.cpc.2010.12.021
- mike
Dear Axel and Michael,
Following the latest documentation, available on the website, I have
newton off
pair_style lj/cut/gpu 2.5
fix 0 all gpu force 0 0 -1
while running (mpirun -np 16 ./lmp_openmpi < control), the GPU section
of the log :
newton off
of the log :
- Using GPGPU acceleration for lj/cut:
- with 8 procs per device.
GPU 0: Tesla C2050, 448 cores, 1.1/2.6 GB, 1.1 GHZ (Double Precision)
Initializing GPU and compiling on process 0...Done.
Initializing GPU 0 on core 0...Done.
Initializing GPU 0 on core 1...Done.
Initializing GPU 0 on core 2...Done.
Initializing GPU 0 on core 3...Done.
Initializing GPU 0 on core 4...Done.
Initializing GPU 0 on core 5...Done.
Initializing GPU 0 on core 6...Done.
Initializing GPU 0 on core 7...Done.
and the preceding CPU section is :
2 by 2 by 4 processor grid
Query: Does this still mean the second GPU on the second node is active?
yes. it says, that you are using 8 MPI tasks per GPU.
with 16 MPI tasks total, that corresponds to 2 GPUs.
16 / 8 = 2
i would recommend to also try:
mpirun -np 2 -npernode 1
mpirun -np 4 -npernode 2
mpirun -np 6 -npernode 3
and so on to determine which degree of
oversubscription of the GPU provides the
best performance.
