Hi LAMMPS Users
Does anybody know how to implement harmonic bonded potential as a pairwise potential with a cut-off. Do i have to modify the code for this??
Best Regards
Sreekanth
Hi LAMMPS Users
Best Regards
Sreekanth
If you want a pair style that will implement a harmonic spring which turns
off at some cutoff distance, you'll need to implement it yourself as
a new pair style, or tabulate it and use pair_style table.
Thanks Steve. I am a beginner with LAMMPS. Can you please suggest me any useful reference to implement new pair style and any helpful suggestions.
Regards
Sreekanth
doc/Section_modify.html has instructions on this
Hi Steve
I have changed the following lines in Void PairLJCut::compute(int eflag, int vflag) to modify pair_style lj/cut for harmonic non-bonded interactions. Now, epsilon would correspond to K and sigma would correspond to r0 (equilibrium length). Please let me know if this is sufficient. In my simulation, i also want to use lj/cut along with harmonic non-bonded interactions. How can i give this modification a new name to use it as command in my input script.
rsq = delxdelx + delydely + delz*delz;
// Harmonic_non-bonded 03/10/10
r = sqrt(rsq);
jtype = type[j];
if (rsq < cutsq[itype][jtype]) {
// r2inv = 1.0/rsq;
// r6inv = r2invr2invr2inv;
// forcelj = r6inv * (lj1[itype][jtype]r6inv - lj2[itype][jtype]);
// fpair = factor_ljforcelj*r2inv;
dr = r-sigma[itype][jtype]; // Harmonic_non-bonded
rk = epsilon[itype][jtype]dr; // Harmoin_non-bonded
fpair = -2.0rk/r; // Harmonic_non-bonded
Please comment.
Regards
Sreekanth
For the latter part of my question regarding the change of name, I have added to files named pair_harmonic_cut.cpp and pair_harmonic_cut.h. I modified existing the pair_lj_cut.cpp and pair_lj_cut.h files accordingly. So now, i can use it as
pair_style harmonic/cut 1.5
pair_coeff * * k r0
please let me know
Regards
Sreekanth
Looks fine to me. I presume you are debugging it.
