I know that heat capacity at constant volume(cv) and constant pressure(cp) can be calculated based on fluctuations of energy and enthalpy(Etotal+P*V) respectively. Both cv and cp for water are measured to be 4.18 KJ / Kg mol at room temp. Using LAMMPS, I obtained cv=4.3 (in NVT ensemble) and cp=44.5 (in NPT ensemble) for water(liquid) at room temp. Hence, I’m able to reproduce exact cv, but not cp. I suspect the reason I’m not able to do it for cp is that the pressure fluctuates very large. No matter how I tune the damping parameters for pressure, Pdamp, from 100 fs to 10 000 fs (in real units), I got pressure fluctuates at plus-minus 1000 atm. After that, I applied drag from 0.2 to 2.0, and I got the same results. Can someone please guide me?
Send
Thank you.
Regards,
Christopher
Send
Thank you.
Regards,
Christopher
How big is your system? Pressure fluctuations are typically large,
but should get smaller for a bigger system. Aidan may want
to comment on this approach to Cp.
