You can cut and paste the below into your potential file. No
guarantees though. However, using this set of parameters, I got the
same vibrational spectra of Si and O in amorphous SiO2 as Munetoh et
al did in their paper.
Zhun-Yong
University of Illinois
# Si and O mixture, parameterized for Tersoff potential
# this file is from [email protected]...
# values are from Munetoh et al, Comp. Mat. Sci. 39, 334-339 (2007).
# Tersoff parameters for various elements and mixtures
# multiple entries can be added to this file, LAMMPS reads the ones it needs
# these entries are in LAMMPS "metal" units:
# A,B = eV; lambda1,lambda2,lambda3 = 1/Angstroms; R,D = Angstroms
# other quantities are unitless
# format of a single entry (one or more lines):
# element 1, element 2, element 3,
# m, gamma, lambda3, c, d, costheta0, n,
# beta, lambda2, B, R, D, lambda1, A
O(M) O(M) O(M) 3.0 1.0 0.0 64692.1 4.11127 -0.845922 1.04968
1.1632e-7 2.35692 218.787 1.85 0.15
4.17108 1882.55
Si(M) Si(M) Si(M) 3.0 1.0 0.0 100390 16.217 -0.59825 0.78734
1.1000e-6 1.7322 471.18 2.65 0.15
2.4799 1830.8
Si(M) Si(M) O(M) 3.0 1.0 0.0 100390 16.217 -.59825 .78734
1.1000e-6 1.73222 471.18 2.21 0.15
2.4799 1830.8
Si(M) O(M) O(M) 3.0 1.0 0.0 100390 16.217 -.59825 .787340
1.1000e-6 2.04456 378.690 2.21 0.15
3.3305 1856.4947
O(M) Si(M) Si(M) 3.0 1.0 0.0 64692.1 4.11127 -0.845922 1.04968
1.1632e-7 2.04456 378.690 2.21 0.15
3.3305 1856.4947
O(M) Si(M) O(M) 3.0 1.0 0.0 64692.1 4.11127 -0.845922 1.04968
1.1632e-7 2.35692 218.787 1.9 0.15
4.17108 1882.55
O(M) O(M) Si(M) 3.0 1.0 0.0 64692.1 4.11127 -0.845922 1.04968
1.1632e-7 2.35692 218.787 2.21 0.15
4.17108 1882.55
Si(M) O(M) Si(M) 3.0 1.0 0.0 100390 16.217 -.59825 .78734
1.1000e-6 1.73222 471.18 2.65 0.15
2.4799 1830.8
