Hello all,
I need to use a potential developed in the form below, which basically consists of two terms; a BKS (Coulombic and Buckingham) and a Morse term.
I am going to use this potential for simulation of Ta2O5 oxide. I am using hybrid/overlay pair_style to add the BKS and Morse terms for Ta-O interactions. The problem I have is that as we can see the Morse term, Dij(1-exp(-aij(rij-re))2 = Dij + Dij [exp(-2aij(rij-re)) –2exp(-aij(rij-re**))], has an extra Dij term as compared to what is mentioned in LAMMPS documentation for Morse potential. As such, when I give the required constants (Dij, aij and re) for the morse term it does not include the extra Dij term in my simulation.
I am using the following command lines to use this potential in my simulation. However, this is obviously not including the Dij. Is there a way to incorporate that term in the simulation?
pair_style hybrid/overlay morse 6.8 buck/coul/cut 6.8 10
pair_coeff 1 1 buck/coul/cut 0 1 0 6.8 10 #Ta-Ta
pair_coeff 1 2 morse 0.3789 1.6254 2.5445 6.8 #Ta-O
pair_coeff 1 2 buck/coul/cut 100067.01 0.1319 6.05 6.8 10 #Ta-O
pair_coeff 2 2 buck/coul/cut 1388.77 0.3623 175.00 6.8 10 #O-O
FYI, the table below provides the constants for the Ta-O pair for both the BKS and Morse terms.
Thank you,
Mahsa Amiri
