Hi everyone, I am doing the tensile test. I want to first enforce
tensile force on the nanowire, then unload it.
I have tried to use fix deform erate command. However, when I set the
erate <0, the following error occurred.
ERROR: Final box dimension due to fix deform is < 0.0
What is the meaning of this error?
So what is the correct way to unload after tension? Many thanks for any advice?
Best wishes,
Han
sjplimp
2
Here is the code that triggers it:
} else if (set[i].style == ERATE) {
set[i].lo_stop = set[i].lo_start -
0.5*delt*set[i].rate * (set[i].hi_start-set[i].lo_start);
set[i].hi_stop = set[i].hi_start +
if (set[i].hi_stop <= set[i].lo_stop)
error->all("Final box dimension due to fix deform is < 0.0");
You can see that you are running long enough at a high enough rate
that your box size will shrink past 0.0. Not good.
