I want to relax the wurtzite structure by SW polymorphic potentiel.
how can we relax this structure?
when I try to do simulation withlammps, I don’t get the same energy found in the article , so I can’t find the solution.
Any help?
#atom_modify
P2 setup box and create atoms and groupen atoms
read struct.data
read_data perfect.dat
replicate 3 3 3
neighbor 2.0 bin
P3 Potential config: Pair style for atomic interactions
pair_style polymorphic
pair_coeff * * GaN_sw.poly N Ga
#pair_style sw
#pair_coeff * * GaN.sw N Ga
timestep 0.001
P4 Define and initialize atomic configuration
#fix F1 all box/relax aniso 0 vmax 0.01 fixedpoint 0 0 0
#velocity all create 0.0 761341
#run 1000
#velocity all create 300.0 761341
P4 Fixes for time integration and constraints
thermo 100
thermo_style custom step temp press etotal vol lx ly lz
variable cohesive_energy equal pe/atoms
run 0
print “Calculated cohesive energy: ${cohesive_energy} eV/atom”
compute atmE all pe/atom
dump D1 all custom 1000 rlx_struct.dump.* id type x y z fx fy fz c_atmE
run 0
P5 Run or minimize
#min_style cg
minimize 1.0e-15 1.0e-15 1000 10000
write_dump all custom sorted_rlx_struct.lammps id type x y z c_atmE modify sort id
write_data rlx_struct.*.lammps
write_data rlx_struct.lammps
