Dear users,
I’m trying to use PRD(Parallel replica dynamics) command. But I encountered unsolved problem that is
“Cannot use PRD with atom_modify sort enabled”
The solution in LAMMPS manual is
“This is a current restriction of PRD. You must turn off sorting, which is enabled by default, via the atom_modify command.”
But I failed to find the way to turn off sorting in atom_modify.
Please let me know If you know the solution.
Thanks in advance
SP
Dear users,
I'm trying to use PRD(Parallel replica dynamics) command. But I
"Cannot use PRD with atom_modify sort enabled"
"This is a current restriction of PRD. You must turn off sorting,
which is enabled by default, via the atom_modify command."
please try setting the sort frequency to 0.
cheers,
sjplimp
#3
atom_modify sort 0 0.0
PRD can't use it, b/c it would mess up the exchange of atoms
between replicas which were sorted differently.
