According to the geometry of the considering structure, I calculated their x,y,z values and copied them into a data file example. Now I want to see the shape of my structure in Windows using VMD. What should I do?
thanks a lot
Samira
thanks a lot
Samira
Hi Samira
Once you install VMD, you need to open the “Tk Console” menu option and type topotools commands to read the data file (using the “topo readlammpsdata” command). I wrote a short README file here:
https://github.com/jewettaij/moltemplate/blob/46bdec1b935282de5279b89d3bf936ad4917b92e/examples/all_atom/force_field_OPLSAA/butane/README_visualize.txt
This README file might not explain everything you need to know, but hopefully it gets you started.
Andrew
