Dear Lammps Users,
If I use atom_style hybrid bond dpd, then should I use fix nve and fix temp/rescale together?
I know that dpd does the thermostatting. So if dpd is used alone, I should use fix nve only.
But what if I have bond also?
I had tried putting only fix nve, but then the temperature is slightly higher then the desired
temperature (I have fixed it to 1.0 but getting 1.1).
snigdha.
