I would like to use hybrid Tersoff and Buckingham potential for a ternary elements (A,B,C) system. The following is the corresponding code in input file,
pair_style hybrid/overlay tersoff buck/coul/long 10.0
pair_coeff 12 12 tersoff sico-nocosi.tersoff A B C
kspace_style pppm 1.0e-4 #for Coulombic items calculation
pair_coeff 1 3 buck/coul/long 18003.7572 0.205205 133.5381
pair_coeff 3 1 buck/coul/long 18003.7572 0.205205 133.5381
pair_coeff 2 3 buck/coul/long 18003.7572 0.205205 133.5381
pair_coeff 3 2 buck/coul/long 18003.7572 0.205205 133.5381
pair_coeff 3 3 buck/coul/long 1388.7730 0.362319 175.0
But I always received the info ’ Incorrect args for pair coefficients’. Does anybody has idea on how should I write the code here?
Thanks a lot.
Tom
pair_coeff 1*2 1*2 tersoff sico-nocosi.tersoff A B C
The Tersoff doc page explains that you must use * * for
the types in this command.
2010/6/16 YuTom <[email protected]...>:
Steve, thanks for reply. So is there any other option to realize this kind of Tersoff/Buckingham combination?
Tom
在2010-06-17 22:08:52,"Steve Plimpton" <[email protected]...> 写道:
>Steve
>> Dear all,
>> file,
>> But I always received the info ' Incorrect args for pair coefficients'. Does
>> Thanks a lot.
>> Tom
>> ________________________________
>> 网易为中小企业免费提供企业邮箱(自主域名)
>> ThinkGeek and WIRED's GeekDad team up for the Ultimate
>> GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
>> lucky parental unit. See the prize list and enter to win:
>> http://p.sf.net/sfu/thinkgeek-promo
>> _______________________________________________
>> lammps-users mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/listinfo/lammps-users
You haven't explained what it is you are trying to do.
The pair hybrid (or overlay) doc page explains what
it means to use a manybody potential like Tersoff as
part of the hybrid command. You cannot specify
Tersoff for atom types 1,2,3 and then "turn-off" the
Tersoff between types 2-3 only. That is not what
a many body potential means.
2010/6/18 Tom Yu <[email protected]...>:
I would like to try two cases:
- use Tersoff just for 1 and 2 (include 11 12 22), and use Buckingham for the rest (13 22 23 33). This means I do not want to just turn off the 23 interaction only, but to turn off all the interactions related to 3, as the Tersoff potential is only good at modeling of 12 system.
- use Tersoff for all the elements, and use Buckingham for some of the interactions too. in this case, there are some overlaps.
在2010-06-19 22:11:43,"Steve Plimpton" <[email protected]...> 写道:
>Steve
>> Tom
>>>Steve
>>>> Dear all,
>>>> file,
>>>> Thanks a lot.
>>>> Tom
>>>> [email protected]
1) can be done with pair_style hybrid
2) can be done with pair_style hybrid/overlay
In the first case just defined Tersoff for types 1,2 and set type 3 to NULL
in the pair_coeff command for Tersoff. Then add your Buck for the
other interactions
In the second case, define Tersoff for all types 1,2,3
Then add Buck on top of it.
2010/6/21 Tom Yu <[email protected]...>:
Hi, Steve, I just tried the first case, but always got “ERROR: Invalid pair style”. The following is the input file,
atom_style charge
pair_style hybrid buck/coul/long 10.0 tersoff
pair_coeff * * tersoff sico.tersoff Si C NULL
Is this related to the atom_style? I am not sure if the ‘charge’ option can be used for Tersoff potential.
Tom
If I run this input script with the current LAMMPS I get no errors.
Did you bulid LAMMPS with the 2 pair styles that you are using?
E.g. are they in your src dir?
atom_style charge
lattice fcc 0.8442
region box block 0 5 0 5 0 5
create_box 3 box
pair_coeff * * tersoff ../potentials/SiC.tersoff Si C NULL
2010/8/17 Tom Yu <[email protected]...>:
