Dear Steve:
I am currently implementing a new type of pairwise interaction into LAMMPS. The basic idea is as below:
Each step, first loop over all the pairs to find the pair with minimal pair distance; for this pair, when the distance is smaller than (r<r1), use potential 1 ( FENE® ), otherwise use potential 2 ( FENE(r1) ); for all other pairs, use potential 3 (LJ potential with cutoff=1.13).
since it is a bit different from most pairwise interactions in LAMMPS with uniform potential. I have two general questions:
Besides writing the new *.cpp and *.h files, is there any other file than style_user.h that will be affected ?
about the program structure of this new module: it seems that following the same structure as existed one and adding the same loop (to find minimum) to the beginning of compute(), init_one(), single() separately is not an efficient way. would you please give any suggestions?
Also any comments on this try are welcome.
Thanks in advance!
Zhenlong Li
PhD student
Macromolecular Department
Case Western Reserve University
