Hi everyone,
I want to put different numbers of ionic liquids in a structure.
Is it okay to put ILs randomly into the structure with Packmol and use the fix tfmc command in LAMMPS to fix the coordinates?
I would be very grateful if you could instruct me.
Ali Molaei
Hi everyone,
the best way to determine whether you get the desired result is to give it a try with a suitably small test system and observe if it can produce the expected behavior.
