[lammps-users] instantaneous expansion
Hi everyone,
I want to make silica aerogel. According to this article’s procedure (https://doi.org/10.1021/acs.jpcb.7b03184), there is a need for instantaneous expansion after making amorphous silica.
Unfortunately, I do not understand how to apply instantaneous expansion in the LAMMPS.
I listed the steps below:
  1. heated to 7000 K (NVT ensemble)
  2. Quench to 300 K (NVT ensemble) + conjugate gradient minimization
  3. Relaxing structure @ 300 K and 1bar (NPT ensemble)
  4. relaxed at 300K for 7.5 ps followed by instantaneous
expansion to the desired density.
  1. Heated to 3000 K for 50 ps(NPT ensemble)
  2. Quench to 0 K (NVT ensemble) + conjugate gradient minimization
  3. Relaxing @ 300 K and 1bar (NPT ensemble)
I would be very grateful if someone could guide me.
Ali
Please look at the documentation for the change_box command. That is truly instantaneous (even beyond what is physically possible in an experiment). Or at fix deform, which allows to set the rate of expansion.
Axel.
Thank you Axel.
I will work on it.
