Hello List,
I need help to set up a hybrid pair potential with sw and lj. I have made the following script and some variants, but I cannot make it work.
This one goes up to the line “print after morse” and then says: ERROR: Pair coeff for hybrid has invalid style/
(If all are sw or all are morse, the script works ok)
Can anyone point to me what’s the right way to set up this hybrid simulation? If I replace the sw for lj/cut works, so I wonder if there is some
limitation for the use of sw with hybrid (and if yes, whether it can be removed).
A second question: in a hybrid simulation that includes a three body potential such as sw, is the three body loop done for all the atoms or
only the sw ones?
Thanks so much for your help,
vale
units real
atom_style full
special_bonds 0.0 0.0 1.0
#pair_style sw
#pair_style morse 8.
pair_style hybrid sw morse 8.
bond_style harmonic
angle_style none
dihedral_style none
improper_style none
kspace_style none
read_data data.poly24-500mW
newton on
print before morse
pair_coeff * * morse 1. 3.0 3.
print after morse
pair_coeff 1 1 two.sw Si NULL
print after sw
neighbor 2.0 bin
neigh_modify every 2 delay 4 check yes
timestep 10.0
thermo_style one
thermo 50
thermo_modify flush yes
fix 1 all npt 275.0 275.0 500.0 xyz 0. 0. 2000
run 200
data.poly24-500mW (31.8 KB)
two.sw (1.57 KB)
