Hi Steve,
When I compile the latest version of LAMMPS (9Feb11), there is always an error as below:
mpic++ -O2 -funroll-loops -DFFT_FFTW -DLAMMPS_GZIP -fstrict-aliasing -I/opt/fftw/2.1.5/intel/include -c create_atoms.cpp
create_atoms.cpp(173): error: identifier “INT64_MAX” is undefined
if (atom->natoms < 0 || atom->natoms > MAXBIGINT)
compilation aborted for create_atoms.cpp (code 2)
make[1]: *** [create_atoms.o] Error 2
Do you know why?
Below is my make file:
openmpi = Hercules cluster, icc/ifort 11, OpenMPI, FFTW2
SHELL = /bin/sh
#.IGNORE:
add Intel-based OpenMPI to path
PATH:=/opt/mpi/openmpi/intel/bin:{PATH}
FFTW=/opt/fftw/2.1.5/intel
LMPLIB={HOME}/development/lammps/lammps-9Feb11/lib
export PATH
CC = mpic++
CCFLAGS = -O2 -funroll-loops -DFFT_FFTW -DLAMMPS_GZIP
-fstrict-aliasing -I${FFTW}/include
NOALIAS = -fno-strict-aliasing
DEPFLAGS= -M
LINK = mpic++
LINKFLAGS = -L${FFTW}/lib
USRLIB = -lfftw
SYSLIB =
ARCHIVE = ar
ARFLAGS = -rcsv
SIZE = size
Link target
(EXE): (OBJ)
(LINK) (LINKFLAGS) (OBJ) (USRLIB) (SYSLIB) -o (EXE)
(SIZE) (EXE)
Library target
lib: (OBJ) (ARCHIVE) (ARFLAGS) (EXE) $(OBJ)
Compilation rules
.o:.cpp
(CC) (CCFLAGS) -c $<
.d:.cpp
(CC) (CCFLAGS) (DEPFLAGS) < > [email protected]
explicit overrides for files that violate ansi aliasing rules
pair.o : pair.cpp
(CC) (CCFLAGS) (NOALIAS) -c <
pair_table.o : pair_table.cpp
pair_eam_alloy_opt.o : pair_eam_alloy_opt.cpp
pair_eam_fs_opt.o : pair_eam_fs_opt.cpp
pair_eam_opt.o : pair_eam_opt.cpp
pair_lj_charmm_coul_long_opt.o : pair_lj_charmm_coul_long_opt.cpp
pair_lj_cut_opt.o : pair_lj_cut_opt.cpp
pair_morse_opt.o : pair_morse_opt.cpp
pair_lj_cut_coul_long.o : pair_lj_cut_coul_long.cpp
pair_cg_cut_coul_cut.o : pair_cg_cut_coul_cut.cpp
pair_cg_cut_coul_long.o : pair_cg_cut_coul_long.cpp
pair_lj_charmm_coul_long.o : pair_lj_charmm_coul_long.cpp
pair_lj_cut_coul_long_tip4p.o : pair_lj_cut_coul_long_tip4p.cpp
Individual dependencies
DEPENDS = (OBJ:.o=.d) include (DEPENDS)
