Hi all
I am trying to use windows LAMMPS exe file (without mpi). However, every time it gives the error: “Expected integer parameter in input script or data file”. I used the same input file from VC++ directly and it was running perfectly. I need to run the exe file for my work (without c++). Can anyone please give me a hint about the error when I try to run lammps using lammps executable: “lmp_win_no-mpi”. I am also attaching the input files for convenience. Please kindly let me know about this issue.
Thanks in advance
Best regards
Rezwan
poly.data (16.6 KB)
in.poly (716 Bytes)
