yes, error message is not helping much. I tried changing couple of
things in makefile, but get same error message, which does not make
any sense.
if I remove -I and -L flags for MPI (no MPI basically) and use STUBS
instead , the same make file compiles just fine.
So, that means my -I and -L flags for MPI are giving problem , but I
don't know what am I doing wrong. The flags looks right according to
LAMMPS documentation online.
Sorry, I don't know either. You'll need to find someone familiar with
"make" who can debug this on your Mac. It's really a make problem,
not a LAMMPS problem.
it would help to see a few more lines of output before you see the
make: *** [macmpi] Error 1
error message.
cheers,
axel 'they call me mr. makefile' kohlmeyer.
that kind of message would happen, if the master makefile
cannot find Makefile.macmpi (you mention a file named,
makefile.macmpi, try renaming it to Makefile.macmpi and
make sure it is in the MAKE subdirectory).
I did some digging around with all these suggestions. my
Makefile.macmpi was ok, but it seems when I renamed file, it added
some hidden extension to it (Makefile.macmpi.mac) , so that was the
problem. It worked fine once I took out second extension. But, after a
while I got following error. I think it compiled for the most part as
I can see pretty much all .o files in Obj_macmpi directory. Here is
the new error :
