Hi All,
I’m trying to using BNCH.ILP to simulate pure h-BN systems,then I found LAMMPS hold on but no output and no error massages.
I need to replace the interlayer potential of h-BN from pair_style lj to pair_style ilp/graphene/hbn and coul/shield.
Then,I used atom_style full and modified data file.I have complied lammps-29Sep2021 with MANYBODY,MOLECULE,INTERLAYER packages on Linux system.
I found that the log.lammps still 0 bytes and no output,even though I’ve run 24 hours.
What confuses me the most is that LAMMPS doesn’t give any error massages and keeps running.I’ve never seen this situation.
I save the screen output to the log file with the >log command.The log file not update after reading potential files as follows:
Reading tersoff potential file BNC.tersoff with DATE: 2013-03-21
Reading ilp/graphene/hbn potential file BNCH.ILP with DATE: 2020-01-16
CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE
Your simulation uses code contributions which should be cited:
- ilp/graphene/hbn potential doi:10.1021/acs.nanolett.8b02848
The log file lists these citations in BibTeX format.
WARNING: Using ‘neigh_modify every 1 delay 0 check yes’ setting during minimization (src/min.cpp:188)
For simplify,I use a official example file which named in.bilayer-hBN.lmp.
I can run in.bilayer-hBN.lmp sucessfully in version of “LAMMPS 64-bit 9Oct2020-MPI” on Windows systems,but once I run it on Linux system,there wil be same situation like before.
Regards,
Shangang
