I have errors when compiling LAMMPS with openmpi. I use modifed Makefile.openmpi for my Centos5.1 OS
My system specific settings
Those aren't LAMMPS variables it is flagging.
Wende,
First try to run test examples provided by openmpi. If you can run those. Then try lammps. Also see the discussion on similar problem couple of days ago.
Regards,
Vikas
2008/6/23 Steve Plimpton <sjplimp@…24…>:
Wende,
couple of days ago.
if i may add one more comment. since your openmpi installation is
in a non-standard directory, it is quite likely that your mpic++
is actually coming from a different mpi installation. did you adjust
your path? for a proper openmpi installation, you should not need to
specify the include directory or the libraries anyways. that should
be done by the mpic++/mpicc/mpiCC wrappers automatically.
cheers,
Regards,
Vikas
