Hi everybody,
As a newcomer to LAMMPS, I definitely need your help.
I would like to run a simulation with only two types of pair potentials (no bond, angle,dihedral,etc): Lennard-Jones and Coulomb. As a first approach, I chose the lj/cut/coul/cut pair_style.
My input script contains the following lines.
Is it correct to use the line "atom_style charge" combined with the command "pair_style lj/cut/coul/cut 8.75 20" ?
(This script also calls the file system.dat that defines the masse of the atoms and the atoms via the following line:
1 1 -1 -331.074383386 -331.074383386 -1.32953354535 (Atom-ID, Atom-type, Charge, x, y, z))
units real
atom_style charge
read_data system.dat
pair_coeff * * 100 3.5 8.75 20
# Define groups
group water 1
group solid_neutral 2
group solid_charged 3
group cations 4
group anions 5
# temp controllers
temperature water_temp water full
temperature cations_temp cations full
temperature anions_temp anions full
temperature solid_neutral_temp solid_neutral full
temperature solid_charged_temp solid_charged full
velocity water create 298.0 887723 temp water_temp
velocity cations create 298.0 887723 temp cations_temp
velocity anions create 298.0 887723 temp anions_temp
velocity solid_neutral create 298.0 887723 temp solid_neutral_temp
velocity solid_charged create 298.0 887723 temp solid_charged_temp
# Fix solid atom around initial position
fix tether solid_neutral spring/self 100
fix tether solid_charged spring/self 100
# Keep solid temperature constant
fix 1 solid_neutral nvt 1.00 1.00 10
fix 2 solid_charged nvt 1.00 1.00 10
fix 3 water nve
fix 4 cations nve
fix 5 anions nve
# Enforce 2d calculation
fix 1 all enforce2d
# Save results every 100 frames (positions and thermodynamics data)
dump 1 all xyz 100 electrokinetics.out
thermo 100
run 100000
So far it crashes immmdiately. There must be something wrong with the initial position of the atoms or an inproper charge or energy (unit problem). I am looking for the problem but I just would like to know if I am going in the right direction.
I have another question. Most of the atoms are not charged, so the LJ potential is enough. Some atoms are charged, therefore I need to had the Coulombic interaction. But so far all the atoms undergo both potentials. I just put either a zero or non-zero charge whether the atom is interacting with LJ or LJ+Coulomb.
Is it possible to run the LJ potential only on some types of atoms and run both LJ and Coulombic on other types of atoms ?
I thank you ahead for your help and possible answers.
Have a good day.
