well, this is a very confusing input. your are changing styles many times in quick succession without really using them.
this is chaos and not a good way to do science. so the first step is that you need to clean this mess up and trim it down to what is supposed to be used.
it looks the final pair style setting is:
pair_style hybrid buck/coul/long 6 12.0 lj/charmm/coul/long 9 12 12
and the corresponding pair_coeff settings are (i have reordered them for easier reading):
system.in.settings: pair_coeff 1 1 buck/coul/long 141717.5705 0.271511 0
system.in.settings: pair_coeff 1 2 buck/coul/long 2760000000 0.120000 0
system.in.settings: pair_coeff 1 3 buck/coul/long 141717.5705 0.271511 0
system.in.settings: pair_coeff 2 2 buck/coul/long 141717.5705 0.271511 0
system.in.settings: pair_coeff 3 3 buck/coul/long 1468324.577 0.198913 641.677184
system.in.settings: pair_coeff 3 4 buck/coul/long 288292.468059 0.215172 278.075175
system.in.settings: pair_coeff 3 5 buck/coul/long 9115.382011 0.230006 0
system.in.settings: pair_coeff 1 4 lj/charmm/coul/long 0.023 3.25
system.in.settings: pair_coeff 4 4 lj/charmm/coul/long 0.1553 3.166
system.in.settings: pair_coeff 5 5 lj/charmm/coul/long 0.0 2.058
system.in.settings: pair_coeff 6 6 lj/charmm/coul/long 0.066 3.5
system.in.settings: pair_coeff 7 7 lj/charmm/coul/long 0.066 3.5
system.in.settings: pair_coeff 8 8 lj/charmm/coul/long 0.03 2.5
system.in.settings: pair_coeff 9 9 lj/charmm/coul/long 0.105 3.75
system.in.settings: pair_coeff 10 10 lj/charmm/coul/long 0.21 2.96
system.in.settings: pair_coeff 11 11 lj/charmm/coul/long 0.17 3.0
system.in.settings: pair_coeff 12 12 lj/charmm/coul/long 0.0 0.0
system.in.settings: pair_coeff 13 13 lj/charmm/coul/long 0.71 4.02
system.in.settings: pair_coeff 14 14 lj/charmm/coul/long 0.0005 4.07
system.in.settings: pair_coeff 15 15 lj/charmm/coul/long 0.449657 2.412031
system.in.settings: pair_coeff 16 16 lj/charmm/coul/long 0.17 3.25
system.in.settings: pair_coeff 17 17 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 18 18 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 19 19 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 20 20 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 21 21 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 22 22 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 23 23 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 24 24 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 25 25 lj/charmm/coul/long 0.07 3.55
system.in.settings: pair_coeff 26 26 lj/charmm/coul/long 0.03 2.42
system.in.settings: pair_coeff 27 27 lj/charmm/coul/long 0.03 2.42
system.in.settings: pair_coeff 28 28 lj/charmm/coul/long 0.03 2.42
system.in.settings: pair_coeff 29 29 lj/charmm/coul/long 0.03 2.42
system.in.settings: pair_coeff 30 30 lj/charmm/coul/long 0.03 2.42
system.in.settings: pair_coeff 31 31 lj/charmm/coul/long 0.03 2.42
system.in.settings: pair_coeff 32 32 lj/charmm/coul/long 0.03 2.42
system.in.settings: pair_coeff 33 33 lj/charmm/coul/long 0.0559 2.8
system.in.settings: pair_coeff 34 34 lj/charmm/coul/long 0.1597 3.028
this is definitely incomplete. while you can have mixing between types that have the same substyle, there are many combinations missing.
i.e. while you can have mixing between 434 and 434, there is no pair style defined for 13 with 434 with the exception of the pairs 1 4, 3 4 and 3 5.
there is no mixing possible between different pair styles, so you have to explicitly specify those interactions (and parameterize them, if there are parameters missing).
also, it is not at all straight forward to determine what type of potential function should be used for those. on top of that, there is no mixing for any buckingham potential (the documentation for those pair styles explicitly says that, so you are already missing the combination 2 3 in between the buckingham interactions.
in short, LAMMPS quite rightfully so tells you that you are missing interactions, and quite a few of them. there is no “magical way” to make those suddenly appear.
in addition you have the problem of having inconsistent interactions due to using a hybrid pair style, and then you have some “stray” settings that don’t even match with the general setup.
bottom line, this is confusing and in dire need for cleaning up, and even more importantly you need a long chat with somebody that can explain the physics of your model and teach you how to properly use parameterizations and to properly test them. this is far beyond the scope of the mailing list. the fact that tools exist that allow you to “glue” parameters and settings and style together does not mean that they produce meaningful inputs.
Axel.
