Hello All,
I am trying to model the MD of electrolytes interacting with a cathode using ReaxFF. I made the input data file by converting it from a poscar relaxed by VASP. LAMMPS runs fine until it gives the following output and doesn’t show any output after this.
Neighbor list info …
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 12
ghost atom cutoff = 12
binsize = 6, bins = 2 3 7
2 neighbor lists, perpetual/occasional/extra = 2 0 0
(1) pair reax/c/omp, perpetual
attributes: half, newton off, ghost, omp
pair build: half/bin/newtoff/ghost/omp
stencil: half/ghost/bin/3d/newtoff
bin: standard
(2) fix qeq/reax/omp, perpetual, copy from (1)
pair build: copy
stencil: none
bin: none
Setting up cg style minimization …
Unit style : real
Current step : 0
I have attached the input. I have also attached a stack trace as I saw from one of the earlier posts. However, I do not know how to make use of this information by myself. I tried this using LAMMPS (30 Jun 2020), LAMMPS (24 Dec 2020) and the recent Windows GPU binary code and got the same result every time.
(gdb) where
#0 0x00002aaaaad2503f in ompi_request_default_wait () from /cm/shared/apps/openmpi/intel/4.0.2/lib/libmpi.so.40
#1 0x00002aaaaad69891 in PMPI_Wait () from /cm/shared/apps/openmpi/intel/4.0.2/lib/libmpi.so.40
#2 0x00000000005aa4c2 in LAMMPS_NS::CommBrick::reverse_comm (this=0xe4d580) at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/comm_brick.cpp:541
#3 0x000000000049a18f in LAMMPS_NS::Min::setup(int) () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/min.cpp:319
#4 0x000000000049bb6c in LAMMPS_NS::Minimize::command(int, char**) () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/minimize.cpp:57
#5 0x0000000000455076 in LAMMPS_NS::Input::command_creator<LAMMPS_NS::Minimize> (lmp=, narg=4, arg=0xe7c200)
at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/input.cpp:871
#6 0x00000000004531f6 in LAMMPS_NS::Input::execute_command() () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/input.cpp:857
#7 0x00000000004538eb in LAMMPS_NS::Input::file() () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/input.cpp:230
#8 0x000000000044bf26 in main () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/main.cpp:62
#9 0x00002aaaabd19555 in __libc_start_main () from /lib64/libc.so.6
#10 0x000000000044bf7f in _start ()
Even if I skip minimization, NVT and NPT runs and go straight to NVE runs I still get this with more or less the same final output.
Setting up Verlet run …
Unit style : real
Current step : 0
Time step : 0.01
(gdb) where
#0 ucs_callbackq_dispatch (cbq=0x1) at /cm/shared/apps/openmpi/intel/ucx/contrib/…/src/ucs/datastruct/callbackq.h:210
#1 uct_worker_progress (worker=) at /cm/shared/apps/openmpi/intel/ucx/contrib/…/src/uct/api/uct.h:1917
#2 ucp_worker_progress (worker=0xd99f90) at /cm/shared/apps/openmpi/intel/ucx/contrib/…/src/ucp/core/ucp_worker.c:1746
#3 0x00002aaabd677c94 in mca_pml_ucx_progress () from /cm/shared/apps/openmpi/intel/4.0.2/lib/openmpi/mca_pml_ucx.so
#4 0x00002aaaac3c3124 in opal_progress () from /cm/shared/apps/openmpi/intel/4.0.2/lib/libopen-pal.so.40
#5 0x00002aaaaad2503f in ompi_request_default_wait () from /cm/shared/apps/openmpi/intel/4.0.2/lib/libmpi.so.40
#6 0x00002aaaaad69891 in PMPI_Wait () from /cm/shared/apps/openmpi/intel/4.0.2/lib/libmpi.so.40
#7 0x00000000005aa4c2 in LAMMPS_NS::CommBrick::reverse_comm (this=0xe4d570) at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/comm_brick.cpp:541
#8 0x000000000053f0b4 in LAMMPS_NS::Verlet::setup(int) () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/verlet.cpp:151
#9 0x00000000005033f0 in LAMMPS_NS::Run::command(int, char**) () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/run.cpp:177
#10 0x0000000000454f86 in LAMMPS_NS::Input::command_creator<LAMMPS_NS::Run> (lmp=, narg=1, arg=0xe7c100) at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/input.cpp:871
#11 0x00000000004531f6 in LAMMPS_NS::Input::execute_command() () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/input.cpp:857
#12 0x00000000004538eb in LAMMPS_NS::Input::file() () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/input.cpp:230
#13 0x000000000044bf26 in main () at /data/home/mpeiris1/SOFTWARE/LAMMPS/Projects/lammps5/lammps/src/main.cpp:62
#14 0x00002aaaabd19555 in __libc_start_main () from /lib64/libc.so.6
#15 0x000000000044bf7f in _start ()
Can someone point out any obvious cause for this?Thank you.
Regards,
Chathuranga
INPUT.lmp (5.33 KB)
B.data (27.3 KB)
