Sometimes ReaxFF does require a large number of bonds on one atom. For a
small system, you can try increasing the value of MBONDEF, reducing NATDEF,
and recompiling the library and LAMMPS.
However, it may also be that your vanadium oxide parameter file, which we
have never tested, requires a non-standard version of the ReaxFF potential.
Try talking to whomever you got the vanadium parameters from.
In situations like this, where you are using a LAMMPS potential for a system
that we have not tested LAMMPS on, it is a good idea to compare LAMMPS
forces and energies directly with the original code.
