Hello
How can I use fix npt or fix press/brendsen with triclinic simulation box?
Hello
You can't. But you'll be able to soon. Aidan is working
on this.
When I use _real_ units, I found the energy given in the log file is for the whole system with many particles.
But if I use _lj_ units, the energy seems is for each particle.
Am I wrong? Thanks,
2009/10/27 Peng Yi <[email protected]…212…>
When I use real units, I found the energy given in the log file is
for the whole system with many particles.But if I use lj units, the energy seems is for each particle.
Am I wrong? Thanks,
Hi, Peng:
You are correct: units are normalized for LJ, but not for other unit systems. (See http://lammps.sandia.gov/doc/thermo_modify.html for more details.)
–AEI
Hello
How can I use ‘pair_style peri/pmb’ for several various materials?
Contact Mike Parks (mlparks at sandia.gov) - he can tell you
if this is possible with the current peri/pmb in LAMMPS.
