[lammps-users] Only one frame of lammpstrj file is read by VMD
I saved my simulation dump file as a “.lammpstrj”, and it have worked well so far.
But for one of my dump file, only one frame is read in VMD. (The others work)
The difference of the dump file (the problem thing) from others has some changes in input file.
In my guess, it is because the input file which has the problem has two “run” command.
Could you check the two input file, and let me know how to fix it? (Is the first run command really necessary for equilibrium? If it is necessary, what should I do?)
The problem
# LAMMPS input - silicon nitride with reaxff
#----------------------------- Initial setup -------------------------------
boundary p p f
units real
atom_style charge
read_data practice1
molecule SiN SiH2NH221.data
group ADD type 2
velocity ADD create 500 12345
run 0
timestep 0.1
pair_style reax/c lmp_control
pair_coeff * * ffield.reax.SiN N Si
#----------------------------- Grouping --------------------------------
region bulk prism 0 30.336407 0 26.272099 1.14 8.46 -15.168203 0 0
group bulk region bulk
region surface prism 0 30.336407 0 26.272099 8.46 9.35 -15.168203 0 0
group surface region surface
region addarea prism 10 20 10 20 15 20 -15.168203 0 0
group addarea region addarea
neigh_modify delay 0
#--------------------------------- Minimization -----------------------------
fix mynve all nve
fix Temp all temp/berendsen 500.0 500.0 100.0
fix qeq all qeq/reax 1 0.0 10.0 1e-6 param.qeq
minimize 1.0e-4 1.0e-6 500 1000
unfix Temp
thermo 100
run 4000
reset_timestep 0
# For making the system in temperature equilibrium
#------------------------------- Simulation start --------------------------
fix Temp1 bulk temp/berendsen 500.0 500.0 100.0
fix please ADD deposit 1 0 1000 12345 region addarea near 1.0 &
mol SiN vz -0.05 -0.05
compute mytemp ADD temp
dump dp1 all atom 50 ADD.lammpstrj
thermo 100
run 10000
The well-working input file
# --------------------- Initialize Simluation -------------------------
boundary p p f
units real
atom_style charge
read_data CONTCAR1
timestep 0.1
pair_coeff * * ffield.reax.SiN C H N Si
# --------------------- Initialize minimization to relax surface -------------------------
reset_timestep 0
# --------------------- Define groups -------------------------
region bulk prism 0 30.33640671 0 26.27209887 0 8 -15.16820335 0 0
fix mynve all nve
fix Temp bulk temp/berendsen 500.0 500.0 100.0
dump dp1 all atom 50 CONTCAR.lammpstrj
neb 0.0 0.001 2000 2000 50 final
thermo 100
run 10000
two things:
  1. this is really a question about VMD, not about LAMMPS, so you should be asking it on the VMD mailing list, not here.
  2. you guess is wrong. your “failing” LAMMPS trajectory does not conform to the “normal” requirements of VMD: every frame has to have the same number of atoms. there are some workarounds for it, but as mentioned under 1) this is not the place to discuss it. you may want to consider using some other visualization tool if you plan to frequently visualize trajectories with a variable number of atoms or use dump image or dump movie in LAMMPS.
Thanks Axel.
It works on Ovito visualization tool, but not on VMD. I will use Ovito, but it doesn’t support “ball and stick” style.
Anyway, thank you for letting me know that input file cause the problem.
