Hi!
I’m creating a very big simulation that has a high number of runs in between each other, and would like to be able to track how much time has been spent on each “portion” of said simulation. So just, print the value of the timer from LAMMPS, restarting from 0 after each print of the value.
Normally I would work by splitting the simulation in multiple smaller ones using write_restart/read_restart and using each simulation’s timer, however, due to the file system limitations of the cluster I’m working on, doing as such often causes errors as it either isn’t able to give LAMMPS it’s restart file, or fails to start a new simulation due to node errors.
I have not found any such way to get this information in the documentation. Is the printed “loop-time” from a run possible to be called upon as a variable, and if so, how must the variable be declared?
Thanks a lot for your time and help
