[lammps-users] pair coeffs error with setting up SAM-Au simulation
Hi, I modified the input file and get a different but similar error:
pair_style lj/cut 2.5
bond_style harmonic
angle_style harmonic
read_data data.SAM-Au
pair_style hybrid eam morse 2.5 lj/cut 2.5
pair_coeff 1 1 eam Au_u3.eam
pair_coeff 1 2 morse 0.1378 0.01477 2.56 2.5
pair_coeff 2 2 lj/cut 4.250 1.6629 2.5
pair_coeff 3 3 lj/cut 3.905 0.495 2.5
pair_coeff 4 4 lj/cut 3.905 0.7325 2.5
and the error changed into: ERROR on proc 0: All pair coeffs are not set
I debuged the code with visual studio and this error comes from
pair_hybrid.cpp::init_one, in which map[i][i][0] != map[j][j][0], it
seems they have value 0 and 2 respectively.
Thanks for any hints!
Best
Xiaoyin Ji
Date: Wed, Jan 20, 2010 at 6:28 PM
Subject: Re: [lammps-users] pair coeffs error with setting up SAM-Au simulation
To: Axel Kohlmeyer <[email protected]>
bond_style harmonic
and rightfully so. you have not specified coefficients for all pairs.
where are the interactions for
1-3, 1-4, 2-3, 2-4, 3-4??
BTW. there is more trouble down the road for you.
you were using "real" units, but eam _requires_ "metal" units (unless you
converted the eam file). also your cutoffs for LJ seem very strange
(2.5 Angstrom?) same goes for sigma and epsilon. what units are those in?
actually the error comes from your input.
cheers,
Hi Axel,
Thanks for your reply. I'm still working on the parameters...other
interactions are supposed to be taken care of by harmonic bond and
angle potentials. So if I just define lj/cut for each atom type, this
input file works. However my system requires eam for Au and morse for
Au-S interaction.
What if I never need the potential for, 1-3..etc?
Best
Xiaoyin Ji
Hi Axel,
Au-S interaction.
well, that reminds me, you should take note, that this kind of model
has some limitations. the surface reconstruction can be quite complicated.
you may want to have a look at, e.g.,http://dx.doi.org/10.1126/science.1158532
have you seen pair_style none?
"Pair style hybrid cannot have none as an argument". It seems there
are more work to be done. Thanks for your advise!
Best
Xiaoyin Ji
if you use lj/cut and specify as pair_coeff epsilon=0.0
you should get the same as with pair_style none.
pair_style hybrid lj/cut ... sw ... etc
pair_coeff 1 2 none
Please read the pair hybrid doc page - it discusses
this.
