I want to run a simulation containing carbon nanotubes and iron using, EAM, Tersoff and LJ for Fe-Fe,C-C and Fe-C interactions respectively. LAMMPS documentation indicates the grammar should permit the following:
pair_style hybrid eam/fs lj/cut tersoff
pair_coeff 1 1 eam/fs Fe_mm.eam.fs Fe Fe
pair_coeff 1 2 lj/cut 0.00759200 3.5 9.7625
pair_coeff 2 2 tersoff C.tersoff C C
where Fe is atom type 1, C is atom type 2. This results in error (see * below)
I'd be grateful for any advice or a 2-4 line script segment that is proven to work for EAM and Tersoff.
Nicholas J. Lee
* I continue to experiment with the syntax from the LAMMPS documentation. Other modifications I have tried that also result in error include
replacing 1 1 (or 2 2) with * *. Even though I only want EAM between atom of type 1
removing tersoff from the 4th line - Line 1 of examples http://lammps.sandia.gov/doc/pair_tersoff.html
removing eam/fs from the 2nd line - Line 8 of examples http://lammps.sandia.gov/doc/pair_eam.html
specifying pair styles/coeff separately for FeFe and CC as if they were separate simulations
In case you need more information, I have attached an error log.
error log.txt (5.52 KB)
